4.6 Cam swap
RE: 4.6 Cam swap
Use the "Search" option. There have been countless threads about cams. Give us more info. What kind of car? Stock?Do you plan on going FI? Miles?...If you want a rough idle, get stage 2 cams. Comp makes good cams, so does VT. Or you can get a set of custom cams. A cam swap is not the easiest thing to do. If you feel comfortable or mechanically inclined to re-time your engine, then go for it.
RE: 4.6 Cam swap
ORIGINAL: Roush1986
great forum
great forum
Do a search, this has been gone over before. Don't come here and be a ween & expect any help next time. You barely gave your post 1 hour for a response. You did ask the procedure, it is quite a lengthy swap, as I've done it before - but why would we be so willing to take the time out of our day & do you a favor when someone acts the way you did?
Welcome to MF.
RE: 4.6 Cam swap
ORIGINAL: Dan04COBRA
Great member. [&:]
Welcome to MF.
ORIGINAL: Roush1986
great forum
great forum
Welcome to MF.
[sm=icon_beat.gif] Ha ha...
RE: 4.6 Cam swap
its a stageII roush, it has a diablo chip, underdrive pulley's,bassani high flow h-pipe, magnaflowexhaust,accufab plenum, and intake, 4:10 gears, i think it has a 65mm throttle body, the car feels kind of slow for some reason so im trying to do something that will give it somemore pick up. Sorry bout bein rude!
Matt's 95 Stang
10-05-2015 07:16 AM
