Underdrive pulleys + blower.....
Old Mar 6, 2007 | 03:46 AM
ASUSMC's Avatar
ASUSMC
Default RE: Underdrive pulleys + blower.....
yep the blower isn't turning as much as it should thus causing lost power.
Old Mar 6, 2007 | 03:59 AM
2000GT4.6's Avatar
2000GT4.6
The other bad part about using a U/D pulley on the crank for a FI car is that even if you DO get a smaller pulley for the blower, you will be loosing surface area on the blower pulley, so it will be more prone to slip.
Aka, even if you repully the blower to keep the output the same it will tend to slip more. If your running signficant amounts of boost this can lead to a loss in PSI and belt shredding.
Old Mar 6, 2007 | 11:57 AM
xxkazp3rxx's Avatar
xxkazp3rxx
Are you sure he has underdrive pulleys and not a s/c upper pulley? With s/c'd cars, the smaller the s/c upper pulley is the more boost they create... may want to double check with him, see which pulley he has.
Old Mar 6, 2007 | 01:04 PM
GT03 TJS's Avatar
GT03 TJS
well he had the UDP's on there for a couple of years and just this past month got the blower.....i asked him if he took the UDPs off and went back to stock and he said he didnt need to, that it was working just fine....then again, maybe he doesnt know the inns and outs.....so yes he is running the blower and udp's.....
lol his loss i guess
GimpyHSHS
19
Dec 19, 2023 01:12 PM
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
GimpyHSHS
Sep 18, 2015 12:27 PM
