just got p0358 code
hey guys i was messing around with some wiring on the stang today and i ended up getting a p0358 code which is:
Ignition Coil Primary circuit malfunction.
couldn't find much info on how to fix it?
This is all I could find about that code from my ford service cd
Each ignition primary circuit is continuously monitored. The test fails when the PCM does not receive a valid IDM pulse signal from the ignition module (integrated in the PCM).
[*]Open or short in the Ignition START/RUN circuit.[*]Open coil driver circuit.[*]Coil driver circuit shorted to ground.[*]Damaged coil.[*]Damaged PCM.[*]Coil driver circuit shorted to VPWR[/ul]
Doesnt have a fix sorry
lincolnshibuya
Dec 8, 2015 04:37 PM
