biggest engine?
ORIGINAL: 1fast50
Damn.. thats pretty good for a truck.. my dad has a 150 Supercrew and that thing wit hthe 5.4, really goes when you stomp on it.. i guessthat saying is true"no replacement for displacement.."
ORIGINAL: racer02GTstang
-7,530 cc 7.5 liters 8 V front longitudinal engine with 110.7 mm bore, 97.8 mm stroke, 8.5 compression ratio, cast iron block, cast iron head, overhead cam and two valves per cylinder
-Unleaded fuel
-Multi-point injection fuel system
-69 liter fuel tank
-Heavy duty alternator
-Heavy duty battery
-Power: 183 kW , 245 HP @ 4,000 rpm; 400 ft lb @ 2,200 rpm
i never knew it was that slow... lol... that thing can move for a 8500 lb truck...
it held with a porshe 944 with 6 peeps in the truck and 3 in the porshe... kinda sad for a sports car having a truck keep with it... and its beat civics and accords. lol
-Unleaded fuel
-69 liter fuel tank
-Heavy duty battery
ORIGINAL: ajmodelski
http://www.mustangblog.com/index.php...n-tank-engine/
Here is a 1100ci. engine for ya
As far as 2007 models go, F350 and under(AKA non-commercial), the 6.8L V10 has it in displacement. The 385-series EFI 460s(7.5Ls) held the record for gas V8s until they stopped making them, the largest V8 Ford puts into anything right now is the 5.4L V8 found in F-series trucks and the Expeditions.
yay! i did it right this time [8D]
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
