Jackstand
Old Mar 12, 2007 | 03:01 PM
PushinTheLimit's Avatar
PushinTheLimit
Default Jackstand
I'm needing to loosen up one of the clamps on my exhaust and I'd like to jack it up just a little bit at the rear. Where is a good place to put the jack at if I'm doing this? Just wondering where u guys would jack yours up at.
Old Mar 12, 2007 | 03:06 PM
GolfmanSpeck's Avatar
GolfmanSpeck
Default RE: Jackstand
do you need to raise the body from the suspension? if not you can just jack from the pumpkin!
Old Mar 12, 2007 | 03:09 PM
blueherd02gt's Avatar
blueherd02gt
The rear end [:-]
Old Mar 12, 2007 | 03:30 PM
PushinTheLimit
ORIGINAL: blueherd02gt
The rear end [:-]
Duh... I meant is there any place in particular on the REAR that you should jack from.
Old Mar 12, 2007 | 03:46 PM
clarehills's Avatar
clarehills
Don't jack up the pumpkin (I am assuming you mean the differential) it puts stress on the points where it connects to the axle tubes and drive shaft (I did it a load of times and found out I should not have been doing it [:'(] on this forum, a mechanic confirmed the same to me - it makes sense if you look at what is above the differential to support the weight - nothing!). The pic below shows the safe places to jack up and support the stang, it was posted a few days ago by someone, cant locate the post to thank them, but here it is anyway...
[IMG]local://upfiles/60884/1EF8050E62AB415D8E9702CAC0EC2C5D.jpg[/IMG]
Old Mar 12, 2007 | 03:53 PM
AJ06GT's Avatar
AJ06GT
Honestly, there is no good way to get the back up. When I put my exhaust on my car I just said screw it and jacked it up at the pumpkin. I'd rather not have to do that again but I didn't have much of a choice at the time. The only other way to get it up is to jack both sides up at the same time. You could drive it up ramps as well if the weight being on the suspension is ok.
Old Mar 12, 2007 | 04:38 PM
joeybutts's Avatar
joeybutts
I CAREFULLY jacked up the rear real high with the place on the edge of the body. I think it is the place where the spare jack goes if you get a flat. then i throw the jackstand underneath the subframe with a HUGE block of wood made from 5 cuts of 2x10. Can't be too safe, especially when your car is lowered. I can't get my jack under the car except on the rear points in front of the rear tires. I needa shorter jack!
Old Mar 12, 2007 | 08:18 PM
00perfredgt's Avatar
00perfredgt
Useful pic clarehills. I printed a copy for future reference. Thanks.
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
LivingInThePast
Sep 16, 2015 12:20 PM
6marc5
Nov 5, 2006 07:09 PM
rcobra
May 21, 2006 04:07 PM
67Dan67
Mar 5, 2006 01:45 PM
