how do you remove this
RE: how do you remove this
remove the headlight ****, then the screws and it should pull right off. then unscrew the cluster and unplug the connectors on the back if you want to pull the cluster.
i have had my headlight **** off and the plastic piece unscrewed for a month now, my rpm needle is sticks sometimes [:@] its a easy fix in therory its trying to ghetto fab some contraption thats the bitch....and im lazy.
Note though once you get the cluster out the plastic cover will still be very hard to clean! If not impossible to get all the dust! The glass istself is actually molded to the plastic...[sm=signs003.gif]
jwog666
12-27-2021 08:09 PM
