Cleaning question
Cleaning question
Easy cleaning question; okay so you know the black cover that goes around the inside of our wheel wells and fenders? Well mine is dirty, its not that black and more. Should I wash it and armor all it or something? I want them to look glossy and flossy again! Or should I order somenew ones.. which is annoying but if that will clean it up then I might..
RE: Cleaning question
I assume you are talking about the inner fenders? I put Rhino Lining on mine. It helped with road noise, and all you have to do is spray some Simple Green on it, let is soak a few minutes, then hose off. Black everytime! You can also just use the Simple Green, or any kind of cleaner, and a hard-bristle brush, and that will clean them up also. Hope this helps.
ORIGINAL: DrBob
wait can u explain that a little more, i dont want to mess anything up. those are two different things right? the simple green and the rhino stuff? which should i do first or...?
TfcCDR
09-14-2015 12:08 PM
