Car wont hold RPM Past 3500.. HELP!
03-25-2007, 10:14 PM
RE: Car wont hold RPM Past 3500.. HELP!
Yea... I also think thats what it might be. Looks like I'm gonna be doin a cam/spring swap earlier than I thought.
03-25-2007, 10:15 PM
I ♥ Acer
25 butthole!!!
Quote:
ORIGINAL: havok209
Would the check engine light come on if it was the fuel pressure regulator?
http://www.carrsmith.com/check%20eng...ode%20list.htm
Yes. Only thing is that you usually have to drive it for a while, might take a while for the light to come on.
03-25-2007, 10:19 PM
Quote:
ORIGINAL: reelfast02cobra
25 butthole!!!
lol *** hat
03-25-2007, 10:22 PM
It could be the valve springs like others have said, but it's rare that they would break with what you have done unless you have over revved it.
03-25-2007, 10:25 PM
Well... Its got about 125K miles. So its very likely that it is that. Or do you think that the piston rings might be done?
03-25-2007, 10:33 PM
Find a fuel pressure tester and check it......maybe check or change the fuel filter also......My fuel pressure wasdroppingand didnt set a code...but could see it through the scanner......Borrow a gauge orfind someone that can check it....Place I'd start....
03-25-2007, 10:41 PM
Yea, I'll do that. I just changed the fuel filter like 1 month ago. Guess I'll drop by a mechanic and have him check out the fuel deal...
03-25-2007, 10:46 PM
maybe you need compression rings
03-25-2007, 10:49 PM
I hope not... But thats another thing I was thinking it might be. Im gonna see if the ppl at the shop by where I live have a compression tester. Does anyone know what the normal PSI should be?
