Speedometer does not work
Old Mar 28, 2007 | 09:53 PM
Greco400's Avatar
Greco400
Default Speedometer does not work
Im getting battery voltage to the engine speed sensor, and the other sensor that goes into the trans.
Also i suppose there are gears in the rear end due to a reclabration box that has a red jump wire taped into the cig. lighter then rest of the wires a grey.white,green purple go into the trans.
The Odometer lights up with the milage, but does not turn, and the speedometer does not work either!
What could i check for? Could the box be bad? all connections are tight! Could there be a bad conection in the dash somewhere
Help needed
thanks
Old Mar 28, 2007 | 10:03 PM
sprostang's Avatar
sprostang
I ♥ Acer
Default RE: Speedometer does not work
Something tells me the speedcal is bad. Remove it and hook everything up like it was from the factory and go from there.
Old Mar 28, 2007 | 10:08 PM
Greco400's Avatar
Greco400
hey sprostang, if i remember right that the wires coming from the box has its own connectors that are pluged in but where would be my stock ones?
Old Mar 28, 2007 | 10:11 PM
sprostang's Avatar
sprostang
I ♥ Acer
There is an article somewhere about how to hook up a speedcal. You would just have to do the reverse. I can`t seem to find the article. I`m gonna try to look a little more. I`ll post it if I find it.
Old Mar 28, 2007 | 10:19 PM
sprostang's Avatar
sprostang
I ♥ Acer
Got it. Heres the instructions.
http://www.dallasmustang.com/page/speedcal.inst.php
Old Mar 28, 2007 | 10:21 PM
Greco400's Avatar
Greco400
Alright thanks man! Should i try disconnecting the battery and go from there, the battery was dead when i bought the car, theres a fresh battery installed now, should i reset it or just unstall it ?
also could the speed cal be bad?
Old Mar 28, 2007 | 10:25 PM
sprostang's Avatar
sprostang
I ♥ Acer
Yes, disconnect the battery like the article says. And yes, the speedcal may be bad.
Old Mar 28, 2007 | 10:51 PM
Greco400's Avatar
Greco400
I disconeccted my battery and still nothing, How do i return it back to stock to elimate the speed cal
It seems like will need the new conections?
articman
Jun 21, 2018 11:45 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
