bleeding brake system
Im in the middle of changing my front brake pads and all i need to do is bleed the brake system and the brakes arn't tightening up. I am full on break fluid!
1996 GT
1996 GT
RE: bleeding brake system
IF its not bleeding out all the way you might need to bleed the entire brake system. Start at the right rear then go to the left rear then the right front then the left front. On each wheel repaet this process 2 or 3 times. Have someone inside the car pump the brakes 3 times and hold it to the floor (obviously with all bleeders closed). While theyre holding it crack the bleeder screw of the wheel youre working on. Repeat then move to the next wheel. Always keep an eye on the master cylinder to make sure it doesnt run dry.
If that doesnt work, you might have a plugged line somewhere.
-P.
-P.
Brake fluid is hygroscopic..meaning water sponge. If you don't bleed your brakes, you tend to get pockets of corrosion in your lines or your calipers start to stick from dirty fluid. Always a good maintenance item to do when working on brakes.
ORIGINAL: Derf00
09-16-2015 07:53 PM
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
