Piston to spark plug contact. Any ideas?
I have an 01 Roush thats pushing about 11psi. I've had the blower on the car for about 1,000 miles now and last week I started to have a miss. I pulled the plugs and found one of them had been pinched off by the piston. I installed a new set of NGK TR6's @ .037 and drove it fine for about 75 miles until I jumped on it again and of course at 5700rpm it seems the piston has tagged a plug again as I have my same ol' miss back.
I'm going to pull the plugs again to confirm but I am almost positive it's going to be gapless again. Is there a shorter plug I should run or am I a victim of rod stretch soon to become rod break? What have you guys done to remedy this? Is there a better solution than installing some quality rods? -Trent
RE: Piston to spark plug contact. Any ideas?
When I had the car tuned and dyno'd the A/F was right on track all across the board with no signs of going lean. Would detonation really close a gap anyhow? I heard no pinging at any point when I was on it... -Trent
ORIGINAL: Quicktimeracing
Read the first post.......http://forums.modulardepot.com/power...-2v-turbo.html
ORIGINAL: JayC
True, but conditions change sometimes. I've seen/heard of several plugs being closed by detonation as well as several engines exploding and the owner never heard and ping or rattle. Don't take a chance on a nice car[8D]
I just picked up a new plug and pretty cool flash light from Checkers and after looking down the spark plug hole I can see where the piston is marked from contact. I suppose now it's a question of rod stretch or perhaps something else?
ORIGINAL: JayC
Golfsito
10-06-2015 11:02 AM
Omgitsa88Stang
10-05-2015 07:33 AM
mungodrums
Suspension
09-07-2015 07:22 PM
