Blue smoke at start up
RE: Blue smoke at start up
Valve seals. Oil leaks down past the seals into the combustion chambers after the car has been sitting for awhile ( such as overnight ). Then when you start the car in the morning that oil is burned resulting in the brief period of blue smoke. If the smoke is there all the time, then its usually because your rings are shot.
ORIGINAL: BAD FN GT
How urgent is this? Should I run out and get these fixed tomorrow? Will it get worse? Or is the only problem gonna be the smoke?
Gotta be REAL bad for that though.
You might try using a slighty heavier oil.
15 to 20 seconds after a cold start isn't bad (though you didn't say how much it's puffing). When it smokes on a warm start after sitting for 30-60 minutes, or on closed throttle deceleration in gear (high manifold vacuum sucks oil past the intake valve seals), it will be time...
ORIGINAL: BuzzCut
Valve stem seals are the usual cause for this.
8-10 oil leaks are because of this
Unless you have MAC headers and did not clean them out (weld lag)
Later
