swaying left and right in rear end
#21
RE: swaying left and right in rear end
ORIGINAL: ZW99GT
It just body rolls HARD. And when coming to a stop, each side will follow grooves. Its crazy. I do NO aggressive cornering EVER, so I wouldnt know about the oversteer, although I can imagine you are precisely correct.
ORIGINAL: Aereon
front tires doing what? bumpsteer?? follow grooves? or hop a bit in the corners?
yea for some reason there have been alot of gt owners with broken rear sway bars from regular dd... I've been hammering my car pretty hard through corners and havent had them break yet.
Also with a rear sway and no front sway your probably experiencing a lot of oversteer through corners.
With
ORIGINAL: ZW99GT
Rear sway bar could be broken/loose?\
I took the front sway bar off mine, and the front tires will do that pretty severly
With
#22
ORIGINAL: Aereon
bump steer has to do with the front of the car, it's when you hit a bump or any other debri on the road and it causes your car to steer in a direction, that you as a driver, did not intend it to. Main difference is the feel of the car when it's bumpsteer and when its the crappy placement of the uca's. Also in most cases the bumpsteer problem is caused by cheap owners that drop their car with stock struts and no c/c plates. This combo will not allow proper suspension travel, car will not be aligned right, struts will be in a weird position, tires will be worn quicker, and you will feel bumpsteer quite a bit more than you'd like
ORIGINAL: 04mineralgreyGT
I thought what he is experiencing is "bumpsteer"? Guess not. I haven't had this problem in my 04 GT but did get alot of it in my lowered 98 Ranger.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
09-01-2015 08:16 PM
92 5.0stang
08-13-2015 06:46 AM
