I Need Help Quick! - - I Think I Just got Ripped Off
RE: I Need Help Quick! - - I Think I Just got Ripped Off
ORIGINAL: 4.6LPoppy
2618 is "harder", but not necessarily "tougher". There is nickel and sometimes, other alloys in with the aluminum. That and the manufacturing method make the final product. There are some really good 2618 pistons out there. Mahle, worldwide, does more high tech racing than the others. They do Formula 1 and snooty stuff. They make a very good product. The ones I "bought" were about $700+ (no rings) most places. I got them for $560 with ring set. But I don't want to pay that for Ford Cobrarods made by Mahle. They are not the same specs. They may be fine, but won't cost nearly that. Good luck with the rebuild.
ORIGINAL: Mark99GT
Sounds like a killer setup. I dunno if you researched the different forgings, but the 2618s are a little tougher. Did you get them for a steal? There are some stock bore 16cc DSS pistons on ebay right now for 50 bucks no reserve, 20 hrs left. Might wanna check those out.
I spun a bearing and am rebuilding mine with forged internals(sloooowly) too. Cant wait to get it back on the road.
Poppy, I justreplied to your post.......
https://mustangforums.com/m_3038865/...tm.htm#3039828
If you have any questions, just let me know.
Casey
Casey
ORIGINAL: Mark99GT
Think you got em backwards. The 4032 is a little harder and less prone to scuffing, but also less forgiving. The 2618 is tougher because it is a tad softer and can withstand a little more detonation that the 4032. However, with the 4032 you can run a tigher piston/wall clearance because they don't expand as much. 2618s can be noisy on start up because of piston slap; the result of the required larger piston/wall clearance. I got a deal on the CP pistons I have, theyre 2618 aluminum. If I didnt get these I would have gone with 4032 pistons. GL with your build too man.
ORIGINAL: 4.6LPoppy
ORIGINAL: Mark99GT
ORIGINAL: Mark99GT
ORIGINAL: 4.6LPoppy
ORIGINAL: Mark99GT
Casey
autoedit
09-27-2015 06:37 PM
09-25-2015 06:30 PM
