02 issues??!??
Old Apr 23, 2007 | 10:09 AM
MineralGrey's Avatar
MineralGrey
Default 02 issues??!??
There are two issues w/the car, it'sis an 02 GT, the first one is whenI pump gas in the car it always cuts off every gallon or so and I have to keep playing w/ the nozzle just to fuel up, the second issue is creaking in the front end especially when I turn from left tor right, My guess is a lower control arm or ball joint, anyone have a clue as to what's going on?, I'm bringing it back to the dealer but I just wan't some knowledge of the issues so they don't try and screw me over. Any help is appriciated thanks!
Old Apr 23, 2007 | 11:15 AM
xcodegt's Avatar
xcodegt
Default RE: 02 issues??!??
the gas pumping sounds like a simple problem of nozzle placement. If a little fuel splashes back on the nozzle, it will cause it to shut off. The squeaking is most likel from the steering rack bushings or lwr control arm bushings. Take some WD-40 and spray down the bushings one at a time. Drive it and if the squeaking stops then the last bushing to be sprayed is the problem. I know it sounds kinda shadetree-mechanic, bu i had the same problems with my 02 and that is how i found out.
Old Apr 23, 2007 | 11:53 AM
Brute03's Avatar
Brute03
i've heard about people having problems filling up before and it wasn't just fuel splashing back on the nozzle, it had something to do with the evap system but i'm not sure exactly. do a search and you should come up with a few things
Old Apr 23, 2007 | 04:46 PM
MineralGrey
thanks 4 the help
Old Apr 23, 2007 | 04:54 PM
POISND U's Avatar
POISND U
Possibly a cloged screen on in the fuel fill pipe?
Old Apr 23, 2007 | 05:34 PM
dirtystang04's Avatar
dirtystang04
My 04 had a squeaky front end when I bought it brand new. I took it to the dealer andit was the steering rack bushings. There was aTSB for them I believe..try taking it to your dealer and tell them about it. If they give you sh** , they are a relatively cheap part so you may want to consider changing them yourself. I don't think an 02 would have issues with a tie rod end or ball joint bushing, just seems like there wouldn't be enough miles on the car to cause that. As far as the fuel issue goes, mine is tricky sometimes. The nozzle can't be too far in or too far out... just gotta find the sweet spot
Old Apr 24, 2007 | 01:18 AM
MineralGrey
thanks alot guys!
Old Apr 24, 2007 | 01:20 AM
jman511115's Avatar
jman511115
http://paladinmicro.com/MyMustang/Mu...ingRackFix.htm
Take a look at that.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
