Driveshaft vibration problem with LCA's??
Anyone here ever experience or heard of problems with driveshaft vibrations due to Aftermarket Lowere control arms? I put in Lakewood Traction bars which alter the pinion angle with a 3/4" drop and have a slight growl coming from the rear when I let off the throttle. It's kinda loud if I'm going fast since there's more presure on the *** end when you go faster and over bumps. If I have a passenger in the car is very aparent. Almost seems the driveshaft is the noise since the rear diff rolls away from the tranny when the gas is pressed and rolls torwards when gas is off. I just don't know if the driveshaft is pushing into my tranny to far causing this problme. IT'S NOT my gears and IT'S NOT bad U-joints! Thanks
RE: Driveshaft vibration problem with LCA's??
I had the exact same problem when I installed my MM LCA's. Before the install, I had no vibrations or noises at all, then allof a sudden after the install, I have, what seems to be, an off-balance driveshaft (which is a FRPP Alum. Driveshaft). I'm getting the DS balanced hoping that's what it is. I don't know how changing the LCA's could do that.
ORIGINAL: nathansee3
With any drop1.5 or over you are going to need to change pinon angle.
You should check your Thrust Angle to see if maybe something isn't completely lined up either... Also, if you are still on a stock rear diff w/ some decent mileage, any change to pinion angle would result in noise, since you're now applying a different force to a different part of the semi-worn gears...
Just a thought though...
JT
JT
Rear gears possibly, and if you drive it around a lot w/ drivetrain vibration, it starts eating away at things like your trans. bearings/races, gears, and eventually, maybe even the engine's bearings (main/crank/etc..) so it's better to have it checked sooner..
JT
JT
ORIGINAL: GodAmGT00
JT
JT
Galactic
04-29-2019 02:56 PM
Luke9222
10-22-2015 11:55 PM
