turbo help!no boost!
RE: turbo help!no boost!
ok .thanks does anyone know where i run my vacum line from and to also someone said that they could be on wrong. where does the vacum from the boost controller go to and all the others??
Ok does your waste gate have 1 vacume hose fitting or 2 (pressure side for 1 vacume for the other)? And how do you root it to your boost controller. I would pass on checking for leaks just make shure you dont have a connection completely off and you will see at least some boost leaks or not. I am pretty certain you have some vacume/pressure line simply hooked up in the wrong places.
Make shure the vacume side wich is the rod side port conected to vacume source. Put the outer port on your intake. Or you can just plug off the vacume port and try just hooking to the intake to make shure the gate is working.
Hey all ust wanted to give you an update. the turbo is working fine and is now putting out 11lbs of pure boost!!! the car is flying and i cant wait to go to the track! i will try and post pics of my homemade turbo system,it is deffinattly alittle funny looking but it does work, anyone can build this kit for under 1100 or so.thank all for your advice you people rule!! o by the way it was just leaking out of the pipes that i had rigged up i took it to the exhaust shop by buddy owns and he rewelded it all up. thanks again!!!
jwog666
12-27-2021 08:09 PM
