Follow-up T-45 to T-56 swap
The swap was easy and I found it to be much easier than just pulling out an old T-45 and putting in a T-45 (removalable bell housing ftw).Things I needed for 2001 (late 2000 build) GT.
T-56 viper spec 6 speed
Drive shaft with matching spline yoke for the T-56
Cross member
Speedo cal box
primary wire.
After pulling out the T-45 I inspected the flywheel and cleaned it up a bit. I extended the speedo wiring by 3 feet (bit excessive), Pre ran the wiring for the reverse lock out. Installed new clutch bolted up tranny housing, installed starter. Installed the T-56, side note here, for my car I did not have to dent the transmission tunnel at all. After that I bolted in the cobra xmember and new driveshaft.
Reverse lockout- I ran the wire to the signal wire on the brake pedal. So basically when I want to shift into reverse I push the brake and it releases the lockout, very easy. You can either spice into the transmission wire or get a gm coolant sensor plug, any parts store on the rack.
[IMG]local://upfiles/59296/12E65E27EE764B769295BED701F732BC.jpg[/IMG]
New driveshaft
[IMG]local://upfiles/59296/DAF263366AC74204A1E6B6268FED36E0.jpg[/IMG]
Bell housing installed
[IMG]local://upfiles/59296/5235B075518E47BB9E02A79F8C812454.jpg[/IMG]
new cobra cross member
Cross member
Speedo cal box
primary wire.
New driveshaft
RE: Follow-up T-45 to T-56 swap
So a cobra bell housing will bolt to an f body t56? My only concerns after the bell housing arethe input and out put shalves, the speedometer, will itwork on a ford? I would think they woud read the same way. so input shalves of the 2 t56's are the same i assume the output salves are as well, and i'm guessing they use the same gear or what ever to measure speed? anyone? thanks
ORIGINAL: ricke9590
The input spline is the same (10) so just get one to match your flywheel, unless you go to a cobra 11 inch, still regret not installing a 11 inch flywheel and clutch, that will be next.
ORIGINAL: AmericanRicer87
Anyone? i thought i'd give this question one more shot, will an f body close ratio t56 bolt to a cobra bell housing? and will the spedo work for a ford?
Matt's 95 Stang
10-05-2015 07:16 AM
