Comp cams Question
Old May 5, 2007 | 10:05 PM
04CompOrangeGT's Avatar
04CompOrangeGT
Default Comp cams Question
I have a 2004 gt that I just had the motor rebuilt in. We put in 10cc dished forged pistons and comp cams XE274H. Yes I know these are npi cams but they sound really good and my tuner said it would not be a problem. Question is I don't know if the guy that built it degreed the cams but the lift on them is only .500 instead of .550 would they still have PTV issues with the lower lift? I have started the car to check for leaks and it runs fine.
Old May 6, 2007 | 10:06 PM
04CompOrangeGT
Default RE: Comp cams Question
bump
Old May 7, 2007 | 01:17 AM
Reed44's Avatar
Reed44
No you will be fine. If you do upgrade to the 550 lift, which I suggest you do, then you will have to get adjustable cam gears and retard it two degrees.
Old May 7, 2007 | 02:06 PM
04CompOrangeGT
Cool I was just wondering about it.
uberstang1
Dec 7, 2017 07:10 AM
Luke9222
Oct 22, 2015 11:55 PM
uberstang1
Sep 20, 2015 06:42 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Luke9222
Sep 4, 2015 06:46 AM
