Fidanza and SPEC
Fidanza and SPEC
Last weekend I installed a Fidanza aluminum flywheel and a SPEC 2 clutch (with lightened pressure plate).
Inow hear a rattle in third gear @1500 rpm which I think is the flywheel. Hasanyone else experienced this problem?Is the SPEC 2 clutch compatable with Fidanza? The SPEC web site suggested SPEC fly wheel with their clutch, but I though that wasjust marketing. Now I'm wondering.
Does anyone else have this set-up?
Thanks.
Thanks.
RE: Fidanza and SPEC
I would be willing to bet on the fidanza because it has the removable friction surface, one of the nuts might not be on tight enough. Your always suppose to check those things when you buy the.
Cavedawg
09-17-2015 09:51 AM
