Those with subframe connectors...
Old 05-15-2007, 06:48 PM
03GRAYGT
03GRAYGT's Avatar
Default RE: Those with subframe connectors...
$250 What are they having hot, naked chicks weld them in?
03GRAYGT is offline
Old 05-15-2007, 07:02 PM
1hotdrp
1hotdrp's Avatar
no WAY should it take almost 3 hours to weld in subframe connectors!
my shop quoted me $520 but they were removing the carpet.
1hotdrp is offline
Old 05-15-2007, 11:49 PM
caspermustang
caspermustang's Avatar
i did mine in under two hours with removing seats and carpet and instaled driveshaft loop at same time. be shur to put good under coating on wellds to keep rust off. only cost like 75 for good ones
caspermustang is offline
Old 05-16-2007, 07:12 AM
pengintamer
pengintamer's Avatar
you dont need to remove the carpet. just tack the four corners and do inch sections at a time and let it air cool. if you look at it they dont even weld to the floorboard
pengintamer is offline
Old 05-16-2007, 10:59 AM
PushinTheLimit
PushinTheLimit's Avatar
I've never welded before... so using this as a starting project is not wise imo. I'm not sure if this is a difference or not, but these will be the full length subframe connectors... I took it that there are different SFC's but I don't know. Maybe thats why it takes longer to do??
PushinTheLimit is offline
Old 05-16-2007, 02:54 PM
M1ke
M1ke's Avatar
i was quoted 170 and 200 from different shops
M1ke is offline
Old 05-16-2007, 03:42 PM
racer02GTstang
racer02GTstang's Avatar
ORIGINAL: goldeneagle_10
yea, i had the full length boxed subframe connectors welded on at kar kare for 50 bucks.
racer02GTstang is offline
Old 05-16-2007, 03:47 PM
01GT4.6
01GT4.6's Avatar
I had mine bolted/welded & painted for $60
01GT4.6 is offline
guitarman376
10-11-2015 01:47 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
09-01-2015 08:16 PM
Quick Reply: Those with subframe connectors...
