getting new injectors, do I need a new fuel pump?
I am planning on getting some new 42# injectors soon and I was wondering if I need to get a new pump. Right now I have a 190 lph. Should I upgrade to a higher flowing one? If I shouldupgrade the pump,which one should I get?
Edit: With my setup do I need to upgrade the fuel system? Besides the stuff listed in my sig the car also has an SVO 70mm tb, a pro m 77, and that is about it as far as hp mods go. I figured since the car is supercharged it would need 42#ers but I wasn't sure. I just want to be on the safe side I guess.
RE: getting new injectors, do I need a new fuel pump?
Its the size of the injector that dictates the size of the fuel pump. Engine internals don't play into it. Yes, with 42lb injectors you will need a higher rate fuel pump (255). Do you really need bigger injectors? What else are you doing with your car?I don't have a recommendation on a brand.
ORIGINAL: mikeyb
ORIGINAL: mustdroptop
Please pm spartanstang he is going ape sh*t trying to find stock f pump. Little extra cash for you and hopefully his car problems are corrected.
ORIGINAL: mikeyb
ORIGINAL: Triisomy21
You may as well. They're not that expensive anyway. Get a focus fuel pump. That should be all you need on stock internals.
mrappe
09-26-2015 10:16 AM
