Swap from V6 to V8
Old 05-17-2007, 11:05 AM
Snapsoccer
Snapsoccer's Avatar
Default Swap from V6 to V8
I am thinking of moving up and replacing my stock 3.8 v6 in my 98 stang to a 4.6 from either a 98 or the better 99+ years 4.6 engine. If I could get an engine,trans(both Manual), wire harness and ECU. Is it a simple bolt on? Anyone know what kind of problems I might come accross?
Snapsoccer is offline
Old 05-17-2007, 11:11 AM
Mustanggt9589
Mustanggt9589's Avatar
Default RE: Swap from V6 to V8
O man don't even waste your time. I wanted to do the same thing in my 95 mustang. Wanted to do a swap and everyone told me i was a moron. They said you need pretty much a whole donor car. The break lines, gauges, computer, wiring harness. I just finally gave up and bought a 03 GT. it will be cheaper in the long run. I don't know how much you know about cars, but if you can install yourself, then great. If not its gonna cost you a arm and leg to do the swap
Mustanggt9589 is offline
Old 05-17-2007, 11:30 AM
czwalga00gt
czwalga00gt's Avatar
You can and if I told you what exactly you'd need I'd just be guessing. You can probably sell your car and buy a GT within 2k of what you can get for your car.
I'd say sell it unless you're going to make a huge build out of it. 500+ Hp, then the v6 shell would be perfect.
czwalga00gt is offline
Old 05-17-2007, 01:01 PM
onegreedy
onegreedy's Avatar
I DID IT , from a 1997 v6 to a 1999 gt
it only cost me $6000.00 i could have sold my v6 and with the money i got i could have bought a 99 cobra
you can go here to see step by step
http://greedy.gotstang.com
you need
First I will list the parts that were required to do this swap
Major components
Engine 1999 4.6 sohc 46xxx miles
Transmission auto tranny out of a 1999 gt
Rear end 1999 cobra irs
wiring
Engine wiring harness
Ecu wiring harness
Body wiring harness
Dash wiring harness( has fuse box connected)
Door wiring harness
Under hood wiring harness (has under hood fuse box connected and ccr)
Center console wiring harness
Turn signal harness
Fuel system
Gas tank
Gas tank filler neck
Gas lines from engine to tank
Charcoal canister
Air pump on pas fender
Various fuel lines and hoses
Fpr
Components needed
Gem module( general control module)
Constant control relay module
Ecu
Fuel relay ( trunk)
Srs relay and srsair bags
Abs compressor
Radiator
Overflow tank
Hydramatic brake system( mounting holes are different size needed to redrill out)
Power steering Lines
brake booster
master cylinder
various relays
I did not use it but it is easier to just get a dif steering collum( because of pats and turn signal switch)
Turn signal switch
Gauge cluster
Exhaust system
Cruise control module and cable
Throttle cable
Air filter set up
4.6 exhaust
Door latches
onegreedy is offline
Old 05-17-2007, 01:55 PM
yourmom6990
yourmom6990's Avatar
lol. why dont you just sell it and buy a newer gt. it would be wayyyy cheaper.
yourmom6990 is offline
Old 05-17-2007, 03:00 PM
GreyStang
GreyStang's Avatar
Wow onegreedy they should make your post into a sticky every week there's a new guy asking about a v6-to-v8 swap
It's a TON of work!
GreyStang is offline
Old 05-17-2007, 03:05 PM
andrewmp6
andrewmp6's Avatar
you guys forgot about brakes linkage and other things they are right its cheaper to buy another car
andrewmp6 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Bokeo
10-10-2015 08:28 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Swap from V6 to V8
