Which is stronger? More Pinion Teeth, or More Ring Teeth?
Buying some gears probably tonight. Summit is open till 9 and I was going to drive down and get them. The FRPP 3.73s have 41 pinion teeth:
http://store.summitracing.com/partde...p;autoview=sku
And the way cheaper Summit Racing ones have 41 Ring teeth:
Are the Summit gears worth a crap? Is it better to have more pinion teeth or ring teeth? $50 difference here. Thanks!
RE: Which is stronger? More Pinion Teeth, or More Ring Teeth?
First off....thats a misprint on the 41 pinion teeth...as the gears numbers go up (usually)pinion teeth tend to go down.......But,,,with less teeth on the pinion doesn't nessarly make them weaker......I'm not sure about Summits but jegs brand are actually Motive gear sets....I Pulled the Jegs sticker off to reveil a motive number....And have heard some FRPP gear sets are motive also.....pick your poison....
It's a typo, if the pinion had 41 teeth the ring would have to be 152.93 for a 3.73 ratio and I don't know how you'd cut 0.93 of a hypoid gear tooth. [/align][/align]3.73s = 11 tooth pinion and a 41 tooth ring = 3.72727272727272...:1[/align]
KingRando
10-02-2015 08:06 AM
