Top End Engine Kit
RE: Top End Engine Kit
ORIGINAL: ZW99GT
Hang on, you said, and I quote "im having problems with the patriot heads," but its leaking oil out of the crank/main seal? How is that the heads fault?
Yes, you need a tune.
the only problem im having with the heads is how it runs but i want to fix the oil problem first to make sure it can handle the 88 mile drive 1 way to the dyno shop and handle the dyno itself haha
i cant wait to see what its like after the tune.....did you get yours tuned right away??
ORIGINAL: Sniper6677
so far...im having problems with the patriot heads
mysterious oil disapearing (in the process of fixing that)....runs rough sometimes....going to get it dyno tuned soon as i sort my oil problem...ill let you know my numbers when i get it dynoed but i dont think ive made much of a power improvement from them...but ill let ya know if your serious about them when i get the numbers
best way you can get power if go for the SVO heads and intake, they bolt right up to our 96-98 stangs. then i don't know much bout cams but just get a stage 3 cam or something, CAI, big throttle body+plenum. that's a good top end kit i would believe. but will cost money as said.
ORIGINAL: BuzzCut
You aren't the first to have trouble with Patriot. They would never get my money. Foxlake/Steen/VT/Boss330 would be the ones I talk to. You just don't have issues with them people.
mine wasnt tuned right after, but it was bad bad b4 then
bcuz its spraying out around the crank pulley bolt
NorthAmericanTuning
03-18-2016 11:21 AM
Choppertwo
3.7L V6 Technical Discussions
08-18-2015 02:21 PM
