Technical gear question
Old May 23, 2007 | 05:59 PM
99shadowGT's Avatar
99shadowGT
Default Technical gear question
This isn't another should i get 3.73's or 4.10's. I'mleaning towards 4.10's, just wondering if I should also get the instal kit. I have 72k on my 99, so im figuring to be on the safe side it's a good idea...any other opinions? I'm also opting for a speed cal instead of a tuner right now, so any info on where to get them for the best price would be great. thanks
Old May 23, 2007 | 06:02 PM
arcticman37's Avatar
arcticman37
Default RE: Technical gear question
Yea Id say go with the install kit it willsave you alot of money from having someoneto have to tear your rear end apart again.
Old May 23, 2007 | 08:10 PM
Black_03GT's Avatar
Black_03GT
yea, I would definantly get the install get. I think i payed 30 bucks for mine. Will be way worth it in the end, like he said keep someone from ripping it apart agian.
Old May 23, 2007 | 09:30 PM
SINISTER's Avatar
SINISTER
I agree, if you're already in there, go ahead and change the bearings and races and all that stuff. When I did my gears, I went ahead and replaced it all and I was at 50k miles.
Old May 23, 2007 | 10:30 PM
Firestang55's Avatar
Firestang55
I was wondering the same thing. I only have 22000 miles on mine. Are the bearings generally damaged when they are removed?
It's 36 for the install kit, and 76 for the bearing kit at american muscle, so $40 dif.
I guess $40 isn't really that much to spend for no worries. I'm gonna go with the full kit.
Old May 24, 2007 | 02:38 AM
SINISTER's Avatar
SINISTER
The carrier bearings get destroyed when they pull them off, but you don't have to worry about that if you are re-using bearings and not replacing your carrier. The pinion bearing was fine when it was pulled off though.
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
