Handling Mods...
Handling Mods...
I am going to be getting my 4.10's next month and I don't plan on any type of FI because I will be getting a Vette, Shelby Cobra, New mustang or something else when I pay this off in a few years. There aren't really many performance mods that I see worth it. I got my catback and I will be getting 4.10's and a midpipe. I am not going to bother with any intake mods.
Handling mods will be my next step other than visual stuff. How will handling mods rank in order?
Sub-Frame Connectors
Panhard Bar
Upper and Lower Control Arms
Shocks/Struts (I only have 13k miles on my stock ones)
Strut Tower Bar
Thanks for any help. I am trying to plan out my mods in order for the summer and the rest of the year.
Panhard Bar
Strut Tower Bar
RE: Handling Mods...
I would go subframes, panhard bar, lowercontrol arm, shocks/struts.
I would never recommend aftermarket uca's to anyone. If your going with a panhard bar and an aftermarket lca, get rid of one of the stock uca's and call it a day.
Most people have the mentality that if steeda or some other company sells a uca then it must work, but if your goal is handling get rid of the 4 link and look into 3 link setup. Also depending on how much of an increase in handling your looking for, look into some Coilovers, I would recommend some koni's, tokico's, or bilstein coilovers. MM and Griggs makes some awesome coilovers. The MM one does not require you to have an aftermarket k member like some of ther others will for the coilovers to sit right.
I am currently running the mm coilover's, mm subframes, and mm lca's. I have the mm phb and mm torque arm sitting in my room awaiting install. Also, before you start on your suspension I would goto corner-carvers.com and use the search function, read up on what they have to say about handling products, they do not believe in going with name brands, but with companies that are performance oriented.
ORIGINAL: 2002GTAUTOVERT
i was told upper C/A are pointless any truth to this?
ORIGINAL: jmac72187
Panhard Bar
Strut Tower Bar
Panhard Bar
Strut Tower Bar
Strut tower brace helps to tighten the front end. Not as noticeable as the subs, except on a vert.
After that, I would consider getting the Bullitt suspension kit if I were you.
It has higher rate springs, bigger (and lighter I think) anti sway bars and upgraded shocks/struts. It lowers your car a wee bit as well.
Personally I wouldn't bother with the other stuff.
Like the other people said, get high quality parts and avoid the knockoffs.
If you really want to go crazy, Griggs and Maximum Motorsports make some excellent kits, but they are expensive although worth every penny IMHO.
Aereon makes some great points!
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
