Flywheel Differences?
Old May 28, 2007 | 12:53 AM
AWD4g63's Avatar
AWD4g63
Default RE: Flywheel Differences?
I am swapping the heads. They are almost a direct bolt on.
The flywheel I got has the following writing on it. I'd like to know what this flywheel is from. How do I know what flywheel I need? All the part numbers ive seen are the same from 96-04. I'm windering if this flywheel is from something different.
valeo[/align][/align][/align]340704[/align][/align]wf2[/align][/align]5g20[/align][/align]nodular[/align]
Old May 29, 2007 | 01:09 PM
AWD4g63's Avatar
AWD4g63
What balance of a flywheel do I need? I found out that the flywheel I got was from a 2005+ GT
Old May 29, 2007 | 01:46 PM
oxfordgt's Avatar
oxfordgt
6 bolt and 8 bolt flywheel are pretty much the same. You can use a 10.5 clutch with a t45 and an 11 in clutch with a 3650. I have a 8 bolt flywheel because of my cobra crank. I put the stock pressure plate up to it and it lined up just fine (even tho I didn't use it). You need a 0 balance flywheel for the 4.6L engine. If you got a 8 bolt flywheel for the 4.6l mod motor no matter what year it will work as long as you have an 8 bolt crank, that is the beauty of the modular motor.
Dokilar
15
Oct 16, 2015 08:13 PM
UrS4
Sep 30, 2015 10:13 AM
junior04
Sep 28, 2015 10:53 AM
mrappe
Sep 26, 2015 10:16 AM
