blown clutch?
Old May 29, 2007 | 03:54 AM
St4ng07's Avatar
St4ng07
Default RE: blown clutch?
Did you smell anything? To me sounds more like a cable issue or an adjuster issue.
Old May 29, 2007 | 04:20 AM
Nitti00GT's Avatar
Nitti00GT
ORIGINAL: kylebgt
Grinding while puttingit in gear is usaully a syncro problem, pedal falling to the ground is the clutch master cylinder giving out. Does the pedal still fall to the floor or does it feel like it has pressure behind it? ImoI think that you must have shaterred the **** out of one side of the clutch.
We don't have a clutch master cylinder. Our cars have clutch cables. I have had my clutch blow on me before and it sounds like a bad grinding but the clutch pedal was normal. Just last thursday I was pulling out of a parking spot and my clutch cable kinked on me and broke making my pedal go limp and the trans stuck in reverse. I had to turn the car off to get it from slamming into the car behind me. Have the shop check the clutch cable before anything. My bet is that it's the cable because the pedal went limp and like I said my pedal was fine after my clutch blew.
Old May 29, 2007 | 04:26 AM
02WhiteGTVert's Avatar
02WhiteGTVert
sounds like it could be the cable/fork..i have a similar problem in my old foxbody..i put a new clutch in it,forgot to bolt the cable back on the support bracket and my hooker super comps burnt my cable all to hell. did almost the same thing that you're saying..oh well..at least i learned how to float gears in a 'stang
Old May 29, 2007 | 04:30 AM
Nitti00GT's Avatar
Nitti00GT
Yeah I think my LTs did my cable in too. I have to get the new cable away from the headers. Also on my friends GT his LTs melted his brake lines. I am going to a dealership and ordering the brake line heat shield that they gave my friend.
Old May 29, 2007 | 10:32 AM
gjscott's Avatar
gjscott
Cable or quadrant gear ?
Old May 29, 2007 | 10:39 AM
OzzDOA's Avatar
OzzDOA
+1 on the clutch cable. The pop you heard was the cable snapping.
Old May 29, 2007 | 06:55 PM
wgdt21's Avatar
wgdt21
thanks for all the help guys, I heard back from the shop today and it was deffinately the clutch.
I was going to order a spec stage 1 or 2 clutch, but they recommened Zoom clutches instead. I havn't heard too much about them, are they any good?
Either way, i should have my car back tommorow or the next day, and my springs are going on while its there
Old May 29, 2007 | 07:54 PM
svt_97cobra's Avatar
svt_97cobra
I ♥ Acer
I would go with a spec stage 2
Old May 29, 2007 | 08:56 PM
Nitti00GT's Avatar
Nitti00GT
Yeah when my clutch went I got the SPEC Stage 1 but if I had to do it again I would go with a Stage 2. I heard somewhere that a SPEC Stage 1 is still good on cars that run low 12s. When I am done school I am getting a TKO 500 or 600 anyway with a new motor.
Old May 29, 2007 | 09:20 PM
88 GT n loven it....'s Avatar
ORIGINAL: 00TropicGreenStang
ORIGINAL: kylebgt
this happen to me today on my 98 GT while it about to into 3rd and the clutch pedal felt alot softer than usually, so i thought it was the cable but then i get under the car and my brother was pressing the clutch pedal andthe fork would movewhen he would press the clutch pedal and when he would let go it would go back into place so do you guys kno if its my clutch or something else ?
Thunderball
15
Nov 22, 2015 11:49 PM
Dathan
Oct 5, 2015 05:52 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
