Exhaust Leak
RE: Exhaust Leak
ORIGINAL: christoph0134
i just put on my o/r h pipe and someone said they think i have a exhaust leak by the way it sounds is there a way to tell
Seriously though,make sure the exhaust manifold to h-pipe flanges are tight,alot of people don't get enough torque on the last P/S nut on the stud,because it's at an awkward angle. just make sure all your stuff is bolted up good,and when you tighten then,alternate back and forth so they set evenly.
RE: Exhaust Leak
ORIGINAL: 02WhiteGTVert
Park your car on a piece of cardboard and let it run for a while,when you move it,look for exhaust on the ground. If it's there,you have an exhaust leak.......
RE: Exhaust Leak
if you can get under it, you should be able to see some black soot under your car where the leak is located.
if it sounds like someone threw a BB into your exhaust, or if it sounds like a spray paint can when you shake it, it's most likely a leak.
trashxtrash
09-20-2015 10:49 PM
09-10-2015 08:39 PM
