180 degree thermostat?
RE: 180 degree thermostat?
The thermostat will only delay overheating, not prevent it. If your cooling system is up to snuff, it will be able to keep the system temp at whatever the t-stat rating is. I can put a 160* stat in my '71 and it will run at 160*. A 192* stat, and the system runs at 192*. A cheap stat may cause problems, but it isn't because of the temp range, only the quality.
17mpg is way bad mileage in my book. I currently average closer to 25mpg. With the 180, I was down to 21 mpg with poor throttle response. A 20% loss in mileage is fine with when adding FI, but not when changing t-stats.
My '03 runs stronger with the 180° thermostat, mileage is the same--however I have a tuner and am running a 93 octane setup with the spark advanced another 1° to 2° across the available ranges. Prior to the lower temp themostat this (the additional timng advance) was not possible without pinging.[/align][/align]I suspect that a lower temp t-stat with the stock tunecould have a negative effect, also those in cooler climates might find that it's not a wise move...[/align]
ORIGINAL: Colorado_Mustang
