I need help guys!!
I need help guys!!
Ok, I got the Ford billet pedals for my car. I can't get the damn things on. The rubber is so tight that it won't go over all sides of the pedal.....it's fvcking pissing my off. I got the deal peal on so far.[:@] Help!
RE: I need help guys!!
As far as the accelerator pedal goes, you must take the two bolts off that hold it to the firewall and slip off the throttle cable. Then take it out and hammer the pin out and install new pedal. The clutch and brake pedals must get pried on with a couple of screwdrivers and some soap and water. Goodluck!!!
Ok, so I got on the clutch, brake and dead pedal. How the fvck do you do the accelerator pedal?? I tried to hammer the bolt out still attached to the car. It was dark and I couldn't see the bolt to detach the whole thing.
Dont touch that cable!!!! no need! gonna make it harder on yourself, i put in the bullit pedals, and they are a pain in the ***.. get some needle nose pliers and pry out the "bolt" that holds it in. It shouldn't have any threads or a nut, just pull it out, replace the bolt with a real one anda nut when you put the ne wone on! Relax, you got the hardest part done! the brake/clutch! Good luck!
ORIGINAL: Emann0007
