stock air box removal?
Old Jun 4, 2007 | 08:59 PM
GStam66's Avatar
GStam66
Default RE: stock air box removal?
Oh, and if u take off the airbox to expose the filter, make sure its at least a K&N.
Old Jun 4, 2007 | 09:08 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Not Bullitt, this is Bullitt...[/align][/align][/align]
Old Jun 4, 2007 | 09:16 PM
GStam66's Avatar
GStam66
DOH! [&:]
WTF are they then? My friend said either bullitt or billet, must be billet i guess? [&:]
Old Jun 4, 2007 | 09:20 PM
gt_stang101's Avatar
gt_stang101
Lol, yeah, billet, which is the aluminum, or whatever material it's made out of...
Old Jun 4, 2007 | 09:28 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
I'd say they are "billet" in the now common use of the term, although they look like high-pressure formed (stamped) aluminum...[/align][/align][/align]
Old Jun 4, 2007 | 09:32 PM
1BadSonicBlue02GT's Avatar
1BadSonicBlue02GT
ORIGINAL: mustangman5089
if you remove the air box and leave the filter sitting in the engine bay, you will be sucking hot air in instead of cold air from the fender that you get with the stock air box. So leave the box on unless you have a heat shield for it.
I pulled my silencer off and gained like 1 mph. After i pulled it off completely i gained another mph. ButI also had something blockin the air to the K&N Filter. Yes it will help, but not so much if you arent blockin any of the heat
Old Jun 4, 2007 | 11:26 PM
BleedinBlue's Avatar
BleedinBlue
Thanks George, looks pretty good. Added to my list
Old Jun 5, 2007 | 04:02 AM
fiad06's Avatar
fiad06
ORIGINAL: 1BadSonicBlue02GT
what did u have blocking it? i wonder what i could put in there so it can be like a heat shield....
Old Jun 5, 2007 | 04:08 AM
kcp1989's Avatar
kcp1989
When I installed my drop in k&n, I noticed I could just saw off all of the casing just leaving the ring in place under the clamp to hold the filter on. But I have not for the reason that the casing helps alot in keeping the filter cleaner.
dubarado
Dec 23, 2015 01:16 PM
squishbang
Dec 4, 2015 02:29 PM
inyadreems
Aug 21, 2015 09:10 AM
SANDY21
Aug 17, 2015 02:41 PM
WDScott
Aug 17, 2015 06:38 AM
