Aftermarket tach on '00 GT?
Is it possible to hook up my OBX 5" tach (one power, one ground, and one signal wire) to my 2000 mustang gt without buying a tach adapter? When I call the tech lines all I get is "buy a tach adapter", but it just seems as though there should be a way to make it work...so far my attempts have only resulted in a tach reading of b/t 7000 and 8000 at idle, but does increase when I hit the throttle...it is acting like it is being multiplied or something to that effect.
Anyway if anyone has any ideas I would love the help. O and by the way my current set up has the signal wire going to the Crankshaft position sensor in the PCM. The power and ground are secure.
Thanks all
-Tyler
Thanks all
-Tyler
RE: Aftermarket tach on '00 GT?
ORIGINAL: tws1098
Thanks all
-Tyler
Thanks all
-Tyler
I've never tried it with a tach but I have my Raptor shift light wired in at the ECM behind the pass. kick panel on the number one coil trigger wire.However, I also have the raptor set to "one cylinder" mode. I dunno if your tach has that feature.
Tach adapters areinexpensive and safe.
Dan04COBRA
09-30-2015 11:46 AM
09-24-2015 09:18 PM
