IAC Mod Question
Old Jun 16, 2007 | 09:11 PM
St4ngGt's Avatar
St4ngGt
Default IAC Mod Question
I did that IAC mod and was wondering if it lowers your gas mileage. It might just be in my head, but it seems like I've been going to go through more gas with the new gasket. Does that just come with the disadvantages? It also seems to make this gurgle noise when slowing down in gear.
Old Jun 16, 2007 | 09:16 PM
CobraStangGT16's Avatar
CobraStangGT16
Default RE: IAC Mod Question
The gurgle is normal...
The gas mileage (so I'm told) is not normal, but I experience it too. I went from 19mpg to about 16mpg just with this mod alone. I can't explain it, but I think it has to do with the richer mixture when dropping revs. More gas goes out the tailpipes because of the less airflow when returning to idle. Thats my guess.
Old Jun 16, 2007 | 09:29 PM
St4ngGt's Avatar
St4ngGt
So did you just take it off, change it, or just leave it?
Old Jun 16, 2007 | 09:49 PM
St4ngGt's Avatar
St4ngGt
Does anyone else have this problem?
Old Jun 16, 2007 | 10:20 PM
Baron von Munchausen's Avatar
I've been using one on a 5-speed Mach 1 for three years with absolutely no drop in gas mileage after installing it.
Old Jun 17, 2007 | 01:18 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
I've got 17k miles on my custom mod (an aluminum restrictor plug in the IAC inlet hose--see below) and have had no problems of any kind. The revs drop much faster between shifts, accompanied by a nice carburetor-like exhaust burble, and the idle is rock steady at 700 rpm.[/align][/align]Youshould reset the computer's adaptive memory (the KAM, Keep Alive Memory) after this or any TB/plenum/IAC/EGR mod--it appears that many are not aware of this and this could explain the poor idle and perhaps poor fuel economy same have reported. I get a solid 22.5-23.0 mpg on my 100 mile daily commute; with 3.73 gears and at 80-85 mph, andwith one or two 95-110 mph "sprints" while passing a string of semi-trailers not being a rare thing...[/align][/align][/align]
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
Roush05
Sep 10, 2015 12:23 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
