31 Spline Factory Trac-Loc
Are these units any good? I want to upgrade and found this for sale. I didn't know if it would be as good as a aftermarket unit. I just want to get a weak setup. I came out of a 2005+ GT.
RE: 31 Spline Factory Trac-Loc
ORIGINAL: 99StangGTTN
ORIGINAL: airborne22
Wow people should really read over what they have just written!!! I'm assuming that he meant he DIDN'T want to get a weak setup! Lets hope atleast!
There is a guy in the classifieds selling a supposedly factory diff out of I am guessing a 2005+ GT. He said it was a 31 spline factory trac-loc. Being that I know very little about the newer GT's I have no clue what comes factory so I guess that is why I had asked the question to make sure it is in fact a 31 spline from the factory and that it is a quality diff that will withstand high horsepower.
I didn't think the 05+ cars had 31 spline?
If your looking for a cheap (er) setup try to find an explorer 31 spline setup. you can use the carrier from there, but you will need aftermarket 31 spline axles. its cheaper, but the exploerer unit will not be as strong.
on the other hand, MDvaldosta went at least 1.5 60's on this setup with 400 WHP~, a full weight car, and full out slicks.
The S197 (05-07) GTs do have factory 31 spline 8.8rears. These are basically F150 , Explorer ,etc. diffs.Overall, they are pretty strong. If you are going to run one with some descent power/traction, I recommend this.........tear it down, de-burr /smooth the case (remove all sharp edges from factory machining, etc. Rebuild it with the new style cfclutch kit and shim on the tight side.Most the time, half a bottle of friction modifier is enough.
ORIGINAL: HaneyMotorsport.Com
for some reason I feel like this guy is one of those guys who sit on the line at 6200...
waahhhh ta ta ta ta ta ta ta (clutch dump)+ et drags.. (front left wheel knee high).. 1.3 60' ...
hehe
breaking
10-02-2015 01:27 PM
