battery light
Old Jun 26, 2007 | 02:17 AM
SVTBill's Avatar
SVTBill
Default battery light
well it stopped for a couple of weeks
but now sometimes it will come on for like 30 seconds every 20 minutes or so
wtf?
and now my phone charger doesn't work
the one that plugs into the cigarette lighter
the little light comes on on the charger but the phone doesn't take the charge
wtf is up with this?
i remember on a ton of mustang carfax's there was always "electrical system serviced" for the new edges i looked at
i guess im about to be one and this is a common mustang problem
what is is guys?
help plz
Old Jun 26, 2007 | 02:19 AM
jersey98gt's Avatar
jersey98gt
Default RE: battery light
you might be getting a poor connection from your terminals to your battery
blackstallion666's Avatar
blackstallion666
check your alt. voltage sounds like the alternator is going out
Old Jun 26, 2007 | 02:20 AM
SVTBill's Avatar
SVTBill
ORIGINAL: jersey98gt
but it doesnt really flash, it just comes on for a minute or so at a time...every so often
SVTBill's Avatar
SVTBill
ORIGINAL: blackstallion666
oh yeah
i had it checked at autozone
he said it was fine
Old Jun 26, 2007 | 02:24 AM
LetThePoniesRunFree's Avatar
LetThePoniesRunFree
ORIGINAL: SVTBill
oh yeah
he said it was fine
The internal voltage regulator in the alternator may be intermittedly going bad. You said the light goes on every 20 minuets or so. I doubt the guy at Autozone ran it on his bench tester for 20 minutes. Just a thought.
Edit: If you could put a voltage meter on the bat. when the light came on, that would help out.
Old Jun 26, 2007 | 02:27 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
ORIGINAL: SVTBill
I had the same issue for a while. I sent it back to PA Performance. They checked it, sent it back w/ NPF. I put it back on, was fine for quite some time then it started doing it again. I called them, sent it back again, they o/h'd it. No more problems. I can bet your alt is on the way out. Something is happening internally that is intermittent causing the problem.
piotrek53
Oct 13, 2015 06:54 PM
logan409
Sep 26, 2015 07:43 PM
Sep 25, 2015 09:06 AM
Beerman309
Sep 19, 2015 01:16 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
