squealing sound.... help
Old 07-03-2007, 09:27 PM
LetThePoniesRunFree
LetThePoniesRunFree's Avatar
Default RE: squealing sound.... help
ORIGINAL: handyandy
oh no I know for sure its not the alternator. That was just a sideways pic. The first pic is a better one of what I'm trying to show. Its that grey metallic one connected to a pulley to the bottom of the first pic, that thing kinda shakes and I was wondering if that is normal, and the squealing comes from there.
Any other thoughts anyone?
In your top pic, the upper pulley is an idler pulley and the bottom one is your tensioner pulley. The bottom one is supposed to move with it's connecting arm as that is what keeps the tension on your belt. There is a spring in the lower housing of that arm that forces the pulley against the belt. Neither pulley should have much , if any, movement or play in relationship to their axis.
LetThePoniesRunFree is offline
Old 07-04-2007, 12:37 AM
dubarado
dubarado's Avatar
yea the same thing happened to mine.. I believe I still have the video on youtube of the sound... lemme get the link...
Oo yea... howdy y'all .... I know it's been a while since I've been here.
dubarado is offline
Old 07-04-2007, 02:58 AM
handyandy
handyandy's Avatar
Thank you guys, so if the tensioner pulley seems like its shaking how do I tighten it down. How do I stop the squeal?
handyandy is offline
Old 07-05-2007, 11:34 PM
ghstintheshell
ghstintheshell's Avatar
would like to revive this thread because i seem to have the same problem
ghstintheshell is offline
Old 07-09-2007, 12:46 PM
handyandy
handyandy's Avatar
anyway I still haven't taken it in anywhere, could it be a dry bearing, or something loose in there?
Old 07-09-2007, 01:00 PM
Sniper6677
Sniper6677's Avatar
If it is the tensioner the only practical solution would be replace it
Sniper6677 is offline
Old 07-14-2007, 12:20 AM
handyandy
handyandy's Avatar
Default RE: squealing sound.... help, updated
I guess i'm going to replace it. Its the idler pulley. I heard where it was coming from and right when I sprayed some WD40 on it it stopped squealing, so it might be a dry bearing or something. I'm just gonna replace it. I have one question though: I have underdrive pulleys and I'm not sure if the pulley I'm going to replace is stock or not. The previous owner put them on so I dont know which ones came in the kit. Does anyone know if its stock or not? Will this cause problems if I replace just one of the pulleys back to stock? I do know it is smooth, there are no grooves in the one I am replacing and its too the left of the alternator and above the tensioner. Thank you.
Old 07-14-2007, 02:40 AM
TheMustangLoveR
TheMustangLoveR's Avatar
If I'm not mistaken, the only pulleys changed in those kits are the crank, water pump, and alternator so feel free to swap out the idler.
TheMustangLoveR is offline
Old 07-14-2007, 01:49 PM
handyandy
handyandy's Avatar
awesome I hope you are right. Anyone else have any information?
Old 07-14-2007, 02:25 PM
98MustangSTL
98MustangSTL's Avatar
Don't worry, the idler pulley is not included with underdrive pulleys.
Hopefully squels will be gone. Good Luck.
98MustangSTL is offline
Quick Reply: squealing sound.... help
