Drag Rims
ORIGINAL: 8banger
Why would you have to change the studs everytime at the track?1/2 inch spacers and 3 inch wheel studs with open end lugs may work..its gonna be a try and see unless someone has actaully done it and found it didnt work...
ORIGINAL: 2000GT4.6
15 inch rims won't work on the fronts with the 13 inch brake upgrade, and if you did it on the back I don't think it will work either.
The only way to make it work is wheel studs and spacers on the front, but its a major PITA to change the studs every time you go to the track, simply not worth it.
I am not a big fan of the wheelspacers that have the studs in them already, where you bolt them on. Anything that does that HAS to weaken the attachment point, not exactly a good idea on a rim thats ment for drag racing.
unfortunatly, the only cheap solution for a 16 inch racing rim is a steel one, all the 16 inch + aluminum rims (lightweight ones) I have seen are expenisve.
[/quote]
[/quote]
Like I said, I have them on my rear and my wheels aren't falling off. Even if it is a drag car, unless its a 4x4, I doubt there is going to be a lot of torque coming off the front wheels. But ok they suck you're right!
[/quote]
Screw the spacers. I have the same problem you do. Here's a nice, decent looking, CHEAP *** solution.
http://store.summitracing.com/partdetail.asp?autofilter=1∂=CRR%2D3987812P& N=700+4294923107+4294923105+4294755963+4294793322+ 115&autoview=sku
Thanks for the limk. I have 18x9 Enki PKR's now. I want a light weight rim up front for the track. What do you guys think of going with the Steeda light weight ones. Little more than I wanted to spend but if that is all that is out there it may be worth it.
Sep 15, 2015 07:34 PM
