REAR END NOISE , PLEASE HELP DIAGNOSE
Old 07-19-2007, 05:23 AM
  #21
contentsunderpressur
contentsunderpressur's Avatar
Default RE: REAR END NOISE , PLEASE HELP DIAGNOSE
ORIGINAL: CLIFFROD
THE NOISE THAT YOU ARE TALKING ABOUT IS CALLED A TIP IN GEAR WHINE IT IS FROM THE BACKLASH IN THE RING AND PINION BEING OFF THE ONLY THING YOU CAN DO IS REPLACE RING AND PINION OR TRY AND REPLACE THE COPPER CRUSH SLEEVE AND SET THE BACKLASH UP TO SPEC
I had something like this happen to mine from taking off at the track with slicks. The force from dumping the clutch and the slicks hooking pressed my crush sleeve a little more. It makes a roaring noise instead of a chirp though.
contentsunderpressur is offline
Old 07-19-2007, 12:34 PM
  #22
adam_ferguson
adam_ferguson's Avatar
ya bearings usually make a grating sound. and i tried that e-brake test last night , i was real tired but it didn't seem to make a difference.
adam_ferguson is offline
Old 07-19-2007, 10:36 PM
  #23
03sonicgt
03sonicgt's Avatar
Does the noise stop when you push the brake?? If so, you may have bent an axle from all the launches at the track. It happened to me, I just swapped out my jacked up rear-end for a fully built 98 Cobra rear end, with 31 spline axles. The noise is gone now obviously, but seriously you probably bent an axle it's happened to two other people I know.
03sonicgt is offline
Old 07-19-2007, 10:48 PM
  #24
adam_ferguson
na the noise just gets slower as i slow down , braking doesn't stop it.
Old 05-16-2011, 02:12 PM
  #25
zimkhan
zimkhan's Avatar
I have the EXACT same noise. A chirp-chirp-chirp, that changes with speed. Only shows up after 10mins of driving from a cold start.
I have a audio clip of my noise issue for better clarification.
Its not my brakes. I tried holding brakes/e-brake, no difference.
Have a listen:
http://www.youtube.com/watch?v=zZD4YU8pP84
zimkhan is offline
Old 05-16-2011, 02:14 PM
  #26
zimkhan
zimkhan's Avatar
I noticed its a really old thread.
Did anyone figure out what the problem was? Solutions?
zimkhan is offline
Old 05-17-2011, 02:15 AM
  #27
Demonhead
Demonhead's Avatar
I had the same problem, turns our my rear right axle was bent. Take it to a mechanic, lift up the car and run the car and have the mechanic look at your wheels. In my case my wheel was wobbling and making the chirping noise while violently shaking my car. You might need to replace your bearings too. If braking doesn't change the chirping noise it is most likely your axle or bearings.
Demonhead is offline
Pyrate Dave
09-10-2015 07:30 PM
Dragonus18
09-09-2015 01:21 AM
Emblazoned
09-03-2015 10:45 PM
09-01-2015 08:16 PM
Quick Reply: REAR END NOISE , PLEASE HELP DIAGNOSE
