GEM module?
Old Jul 18, 2007 | 02:00 PM
mustangchris09's Avatar
mustangchris09
Default GEM module?
Some of my lights are not working inside, my gauges wont light, nor my radio, and mydoor lockswont work, butthe remote ones do. Also when i set my alarm those lights dont work either. So is it my GEM module i need to replace. I have a code coming up now too p1633 which says " battery disconnect, or open/short circuit condition. I need to get my emissions done so i need to know what i need to replace.
thanks.
Old Jul 18, 2007 | 02:11 PM
Sniper6677's Avatar
Sniper6677
Default RE: GEM module?
what year are you working on??
i ran the code through alldata and the diagnosis pinpoints 4 places[*]Battery terminal condition[*]keep Alive Power (KAPWR) wire routing[*]Harness circuit: KAPWR[*]PCM
check your wiring , engine wire harness, battery wiring, etc
the repairs are all pointing to battery terminals, engine compartment wiring, open repairs, up to PCM replacemnt but that was ran through for a 2000 GT
hope it helps
Old Jul 18, 2007 | 02:38 PM
mustangchris09
Hmmm.... well i guess ill try that and see what i can find, i have an 03 gt so it should be similar i would think correct????
Old Jul 18, 2007 | 02:56 PM
Sniper6677's Avatar
Sniper6677
im not sure....there are differences between them but that's where i would start at least it gives you a general idea
as for the GEM module, looks like it isnt even listed in the DTC flow chart
description:
controls the following
[*]warning chimes and warning lamps[*]one-touch down window[*]windshield washers and wipers[*]battery saver[*]illuminated entry with keyless remote entry[*]interior lighting[*]passive anti-theft[/ul]
lincolnshibuya
Oct 6, 2015 08:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
