Air Filter Replacement
I own a '01 Mustang Cobra, no mods. Trying to find instructions for simply replacing the air filter. There seems to be slightly more involved than when I would change the air filter on my Camry. Any help would be great?
RE: Air Filter Replacement
http://www.mustangworld.com/ourpics/fcar/knln1.htm
I don't know if the Cobra air intake setup is the same as the regular 4.6, but I assume it's probably similar.
This is a pretty good instruction on how to get the old one out. You can of course opt to put in a better filter or not. Hope that helps.
Check this out. http://www.mustang world.com/ourpics/fcar/knln1.htm(delete the space between "mustang" and "world" in that link.)
Even though the illustration is geared towards changing out the factory filter with a K&N filter, the procedure is the same if you want to replace your air filter with a factory replacement.
ShaneB26154
35
03-04-2021 04:05 AM
Calizic
08-28-2015 01:46 PM
