Tach Help
Old 07-20-2007, 08:20 PM
benk87
benk87's Avatar
Default Tach Help
Ok there is something wrong with my tach in my 98 GT... When I am driving down the road... and say I am going at 2000rpms... well my tach will say that but then all of a sudden it will jump to like 3500 or just any other random number... Sometimes it will just stick there and not move... Most of the time ... I will kinda tap the front plastic that is on the cluster and it will go back to where it needs to, but a few seconds later it will act up again... Do you guys think this is either a bad tach, loose connection, or their is something that is inside the cluster I cant see?? I belive on the 98's the tach is electrical and the speedometer is run buy a cable... I need help!!! Ben
benk87 is offline
Old 07-21-2007, 04:42 AM
adam_ferguson
adam_ferguson's Avatar
Default RE: Tach Help
sounds definatly like a wiring connection issue. tappin on the glass lead me to that , cause you are probably altering the loose connection when you do that causing it to shift. you'll have to troubleshoot it to find out for sure.
adam_ferguson is offline
bryan616fl
01-25-2019 09:07 PM
96stang3.8
09-10-2015 06:42 AM
Fast302
06-02-2004 05:31 PM
nhdungeonracer
04-12-2004 06:28 PM
gtbeast87
01-21-2004 06:00 PM
Quick Reply: Tach Help
