Will these fit?
Old Jan 23, 2005 | 04:39 PM
98Snake's Avatar
98Snake
Default Will these fit?
I am looking to get some new tires since I went out to my car the other day and I had a flat, on top of them having very little tread life left I figured I mine as well get some new tire. Will 275/40/18 fit on my car without rubbing when I turn. I have a 98 cobra with cobra r wheels. I have 275/35/18 on there now. Which one would be better for what? Also does anybody have any suggestions on where to order 4 tires. I don't want to spend a whole lot of money. I looked on ebay and there are some slightly used goodyear f1s for like 80 a tire. Anybody have any experience buying tires on ebay? Thanks.
[IMG]local://upfiles/9959/BA7A2F54005D4419A5D8D861C04C7DE1.jpg[/IMG]
Old Jan 23, 2005 | 05:42 PM
devinsteen's Avatar
devinsteen
Default RE: Will these fit?
Are you taking about the rear or front tires? I wouldn't run anything bigger than 255's up front. The rear can fit 275/40/18 with no problem. I have 275/40/17 on my car and it does fine. E-bay can be a good source for tires....just have to be careful. Oh, and don't go with goodyear. Get some DR's.
Old Jan 23, 2005 | 05:52 PM
98Snake's Avatar
98Snake
I have 275s up front right now. Why is that not good. Also what are DR's and why over goodyear?
Old Jan 23, 2005 | 05:55 PM
98Snake's Avatar
98Snake
Also what size do you recommend in front and what size in the back. Should they be the same brand in the front and back?
Old Jan 23, 2005 | 06:46 PM
Dan04COBRA's Avatar
Dan04COBRA
275's ar epushing it up front, but hey if they fit...
Anyways, say you go with 255's up front and 275's out back, you won't be able to rotate your tires or anything. Have to take that into consideration.
Old Jan 23, 2005 | 07:50 PM
Aliate X's Avatar
Aliate X
I ♥ Acer
i know this is kinda in the wrong section, but do you guys know whats the max size tire i can fit in my rear of my 5.0 without having the tire stick out of the fender at all? Im getting a wheel/tire package
Old Jan 23, 2005 | 08:53 PM
devinsteen's Avatar
devinsteen
ORIGINAL: 98Snake
Well, I have 235/45/17 in front and they are flush with the fender. I had 255's but they stuck out a too much for my taste. It's really your perference.....you could run 245's up front also.[8D] I say 275/40 or 275/35 since you have 18's. DR's are drag radials.....like Nitto and BF Goodrich. They are much stickier than street radials.
Old Jan 24, 2005 | 01:33 AM
nastystang's Avatar
nastystang
I have the Goodyear F1's on my car 275/17 up front 315/17 int the rear and they are great no rubbing and alot better around corners
Old Jan 24, 2005 | 03:08 PM
beezy's Avatar
beezy
I have 285's all around and i dont rub
Old Jan 24, 2005 | 03:13 PM
DeViouS's Avatar
DeViouS
i think 94-98s have less wheel clearance. is that right?
jwog666
Dec 27, 2021 08:09 PM
mustangheaven
Jan 3, 2016 11:20 AM
BeatnikFink
Oct 1, 2015 08:00 PM
fastbackford351
Oct 1, 2015 12:24 PM
mdg
Oct 1, 2015 07:04 AM
