Oil Change
#21
RE: Oil Change
ORIGINAL: Adam03GT
O so your the bastard who gives us these tiny engines?
And it doesnt take someone with vast knowledge to recomend what oil to use...... Dumbass....
If it says 5w20 why go against it? I honestly dont care why Ford recommends it.... They do so i use it...
ORIGINAL: 01Steed
Yes, I make it a habit to talk out of my ***. [>:]
I'm sure I've learned nothing about this subject in my 10 years of leading an engine design team for a highly regarded Ford design source.
Perhaps you could enlighten the rest of us as to why Ford recommends 5W20? Please, share your vast knowledge with us.
#22
RE: Oil Change
ORIGINAL: 01Steed
Funny, I don't recall reading inmy owner's manual or any other Ford publications that I should replace my conventional "break-in" oil, as you refer to it, with synthetic. I think you're manipulating some facts here to bend this conversation in your favor. Sorry, I'm not buying it.
Is synthetic better? That question doesn't have a straight-up "yes" or "no" answer. It is better if your engine's needs exceed that of what a conventional oil can deliver. If, for instance, your engine requires an oil that won't break down at higher temps, or you don't like changing it every 3-4000 miles, than yes, you might want to consider a synth. On the other hand, you can't buy into any hype generated by the synthetic oil industry that conventional oils are garbage. Think about that....they're trying to sell their product. If they admitted that John Q. Public doesn't really "need" synth, they'd be narrowing their target market, which isn't a good business plan.
But anyhow, my original point is still valid. You shouldn't just blindly tell a person that they "should" be using synthetic. Don't read any more into what I've said. You people are acting as though I said synthetics aren't any good....that's not what I've said.
I'm not going get into a pissing contest over this. The OP hasn't reposted, so it's basically pointless to argue further.
Good luck to everyone. I didn't become a member here to start/participate in arguments or namecalling. There's too much of that going around already. You have your viewpoint and I have mine. Let's leave it at that.
If using synthetic makes you feel better, and recommending that others should likewise be using it justifies, in your mind, that you made the right decision by switching to it, more power to you. I'll stick with the MotorCraft 5W20 in my vehicles, changed every 3,000 miles. See you at 200K+boys....
#23
RE: Oil Change
just a few things. my 2000 gt owners manual says to use 5w-30. another thing is, all the motorcraft oil i see is full synthetic. i work at advance auto parts, and thats all we stock for motorcraft.
#24
RE: Oil Change
I think we scared the guy away. All he wanted was a simple suggestion.
Mobil 1 Fully Synthetic 5w20 and a mobil 1 filter.
No matter who you are or how you drive the car will enjoy it and benefit from it, period. Try to argue with that.
TfcCDR
09-14-2015 12:08 PM
