A/C problem
Today while pulling into traffic my A/C stopped blowing cold. I wasn't at WOT but I was giving it a good bit of gas. After about 2-3 minutes I smelled something burning. I pulled over, lifted the hood, and there was smoke coming from my compressor. After about 5 more minutes it stopped smoking and the A/C began to blow cold again. It blows really cold air just like before but now it whines and knocks really loud. WTF happened??
ORIGINAL: auburntiger7231
Clutch/Pulley is binding.
Iced up compressor. (was it or any of the hoses covered in ice?)
Low on freon (the low pressure switch should have turned if off though)
High on freon (overcharged).
Blocked system.
Low on oil.
...and about 25 other things.
Pull the serp belt off and check for binds in the pulley.
Other than that, you will have to get a set of gauges on it and see what's going on.
Just went thru the exact same thing.The bearings for My A/C clutch had burned up and froze. With the car off you can loosen up/take off the serpentine belt and jiggle the AC pully. It should not have any kind of play in the pully. Also it should be able to spin freely with the belt off. Mine was really rough spinning and made all kinds of noise. If thats the case, you need to change the AC Clutch.
Not too hard to replace at all. Here is a guide I used (http://autorepair.about.com/library/faqs/bl168i.htm) The hardest part I had wasputting on the new field coil and getting it to sit flush on the compressor (it took some hamering). The AC clutch cost $137 andthe snap ring pliers were $17 at autozone (you can get them for $5 at harbor freight if you have one around). Also you can rent the AC pully remover from Autozone.
stangin1996gt
Sep 21, 2015 11:01 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
