T56 SWAP
Old Aug 7, 2007 | 09:21 PM
supersporter69's Avatar
supersporter69
Default RE: T56 SWAP
YEA THE DEALERSHIP HERE SAID A SET OF SYNCROS WAS 284.05 FOR THE WHOLE TRANS AND MY BUDDY CAN DO THE WORK.... I DUNO I JUST WANT IT TO BE ABLE TO HANDLE SOME POWER IM BUILDING MY REAR END AND PUTTING NITROUS AND CAMS ON IT AND DOING A BUNCH OF WEIGHT REDUCTION MOSTLY BOLT ONS WITH NITROUS.. NOTHING HUGE OR ANYTHING??? WHAT DO YOU THINK I SHOULD DO?
Old Aug 7, 2007 | 09:54 PM
Ryan86272's Avatar
Ryan86272
Well, the first time i rebuilt my Tranny, Like you had a Friend that can do it.... then again,3 months later it went again. So i just coffed up my Superchager fund on a TKO........ its up to you honestly, its not going to take much Power but you have CODE that has done MANY MANY MANY MANY Runs on the Stock 3650....... i guess you win some lose some.... Mine were a little cheaper for the Synchros(friend worked at FORd) in the process of Puting the Tranny back togeather we Broke a bearring so i had to buy the Whole Bearring kit....OUCHY!! Good Luck
Old Aug 7, 2007 | 10:04 PM
supersporter69
alright man thanks for all the help
NeedStangSpeed's Avatar
NeedStangSpeed
A TKO would be the better of the evil. T-56 swaps are quite pricey. I was talked out of it by someone on this form. If you get a TKO 500 or 600 based on personal preference, only difference is the first gear ratio, you'll have to get a clutch kit(because of the tranny being 26 spline), bellhousing, and if I'm not mistaken driveshaft may be an issue(not sure) and maybe cross member. Best if you ask someone who's done it, like 2000GT4.6, he's done it and is very knowledgable on it.
Old Aug 7, 2007 | 10:11 PM
Ryan86272's Avatar
Ryan86272
the TKO500- is still a 10spline so u use your stock clutc
TKO600-26 Spline Clutch
You need a
[ul][*]Driveshaft Spacer-(little round piece of Metal you put at the end of ur driveshaft)[*]Crossmember Spacer- Metal Block that goes between Crossmember and Tranny(spaces it out more)[*]Bellhousing- exactly what it says, comes on the Tranny now you can take your tranny out and not mess with your LT's!!!!!
After that i had to Modify my Crossmember,I welded on another plate cause the holes didnt match...
[/ul]
Old Aug 7, 2007 | 10:36 PM
supersporter69
DO YOU GUYS KNOW A BASIC PRICE ON THE TKO'S??
Old Aug 7, 2007 | 10:43 PM
Ryan86272's Avatar
Ryan86272
TKO500's ive seen 1899
TKO600's i think it was 100 more....
I got:
[ul][*]tko600[*]bellhousing[*]Driveshaft spacer[*]crossmember spacer[*]TOB[*]Clutch alignment tool[/ul]
$2430 to my door...
TKO 500
[ul][*]tko 500[*]bellhousing[*]both spacers[/ul]
was 2200 Shipped to the Door.
This was from D&D performance
Old Aug 7, 2007 | 10:51 PM
supersporter69
OHH ALRIGHT
Old Aug 7, 2007 | 10:59 PM
97targa's Avatar
97targa
ORIGINAL: NeedStangSpeed
LMAO. This is the funniest post I have seen in a while! The only diff. is this and this and this and ohh yeah maybe that too. lol
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
UrS4
Sep 30, 2015 10:13 AM
