What should I do with my 2V?
My number 3 and 4 piston ring lands have broke from detonation. I am not exactly sure of what I should do now. I have considered a stroker kit and cams and port and polish my heads but the gains seem to minimal for all that money. Then i thought about going cheaper with just a forged bottom end but the only gains from that is maybe one day I will get a S/C but that will be a long time from now. I have looked into DOHC swaps but they are pretty expensive too. I am lost and can't make up my mind, my cylinder walls need a honing to fix some of the damage. Any suggestions??? Installation prices aren't a problem I can install everything.
RE: What should I do with my 2V?
Get stage II heads and cams, forge the bottom end with the rods and pistons...then put a dual stage wet system on it...a 300 hp kit. If you can do the work yourself, it should cost about 5K. The block is good for 600 hp.
ORIGINAL: 2003GT100
It sounds really great to start pulling prices off the net and throwing stuff on.. but without the supporting mods etc it just doesn't work. Turns a 5k job in to a 10K job really quick. Not only that, but I have yet to see a 2v spray more than a 200ish shot.
