Mod Motor
Mod Motor
Hi i am new to thissite anda recently converted ford guy after ownin 2 ls1 and an lt1....I have a couple questions but my biggest one is whatexactly determines if its a modular motor or not...Im not farmiliar with the term modular motor...any help would be greatly appreciated
RE: Mod Motor
94-95 stangs had the 5.0's too.
And Ford's use of the term "modular" was to indicate the tooling that the engine was produced on. The machines were designed to be able to produce multiple variants of the same engine, hence the 4.6, 5.4, 2v and 4v are the same basic engine.
RE: Mod Motor
WELCOME!!!!
Modular means the same block can accept different key componants to fit differnt situations. That way they can put the same block in more platforms with different heads, cams, crank and so on andget the desired results.
jaiidutch
09-14-2015 10:29 AM
