grinding 2nd sometimes
Old 08-13-2007, 10:21 PM
lexy
lexy's Avatar
Default grinding 2nd sometimes
Hey people just wondering sometimes when i shift to 2nd pretty hard and fast, i likes to grind. T45 tranny, steeda trixax shifter. I feel like the flywheel is spinning too fast or something. Anyways the stock clutch is on the car and its not in the best shape, I have a new clutch by kingcobra. My question is that is the sync gone, or the cluch just not catching fast enough? Let me know thanks MFrs.
lexy is offline
Old 08-13-2007, 10:39 PM
BraMas
BraMas's Avatar
Default RE: grinding 2nd sometimes
Deffinatly syncro's. If your tranny has never been rebuilt it is deffinatly the syncro's. The new rebuild kits come with an improved Syncro kit
BraMas is offline
Old 08-14-2007, 12:09 AM
Quicktime_GT
Quicktime_GT's Avatar
yea my car is sitting right now with no transmission because of this.. but i wrote this cool rhyme..
"you can see me in the stang GT
sittin in the grass with the broke tranny"
yo yo
Quicktime_GT is offline
Old 08-14-2007, 01:32 AM
2000GT4.6
2000GT4.6's Avatar
Grind on a T-45 means the syncs are out, and it means now almost no matter how easy you are on it its going to evenutally break.
Either pull it now, replace the syncs, and then have it happen all over again or wait till it blows and get yourself a 3650, Tko, or T-56.
2000GT4.6 is offline
Old 08-14-2007, 08:32 AM
MrChubs1
MrChubs1's Avatar
Sounds like synchros, but it also sounds like it'll last you a long time if you treat it right. If it's not grinding while driving normally, things are fine, just a bit worn.
Just about any gearbox will grind a bit if you're slammingthe gears really hard.
MrChubs1 is offline
Old 08-14-2007, 10:08 AM
97tplsGT
97tplsGT's Avatar
mine grinds when I "speed shift", but doesnt make a noise while "power shifting" (unless I miss a gear, then eeewwww) go figure . Synchs are going bad buddy, that above mentioned. Ride it out till it breaks, then upgrade, or go agead and get it fixed now before something else breaks.
97tplsGT is offline
Old 08-14-2007, 03:19 PM
BBond007
BBond007's Avatar
ORIGINAL: 2000GT4.6
I lived with a bad 2->3 syncro for a long time. Eventually it started getting real noisy and popping out of 1st, 5th, and reverse.
I lived with that for about 2 months until it eventually further broke and was only capable of going in 1st or N...
Now I have a remanufactured t-45 with upgraded parts and royal purple. Very nice!
BBond007 is offline
Old 08-14-2007, 06:55 PM
MrChubs1
MrChubs1's Avatar
Why not just throw some new synchros in it? If you don't have a press, you can buy one for a couple hundred bucks. A basic rebuild kit is really cheap and you can dothe complete jobin about 4-5 hrs.
MrChubs1 is offline
Old 08-15-2007, 05:34 PM
lexy
lexy's Avatar
What if I drain the fluit and put some royal purple in there, would it help?
lexy is offline
Old 08-15-2007, 08:06 PM
LetThePoniesRunFree
LetThePoniesRunFree's Avatar
ORIGINAL: Quicktime_GT
sittin in the grass
yo yo
Yeah it's a bummer, but that GT sure looks sweet as hell sitting there.
LetThePoniesRunFree is offline
Quick Reply: grinding 2nd sometimes
